I’ve just installed windows 10 pro (64 bit) on a render node. I’m trying to register vrayRT as a service (as I normally do) using the Chaosgroup menu item and then manage the computer/services and then start the service but it will not register.
Any idea why this is happening ?
Which version of 3dsMax and V-Ray are using?
Could you try you to register the service with right click and “Run as administrator” option.
If you still have issues with the registering V-Ray RT render server as a service you could write us an email at support@chaosgroup.com and we will assist you further.
Nikolay Kusht
Technical Support
Chaos Group
