As the scanned materials from VrayScans are very small areas, some Scans would greatly benefit from utilizing the UVWrandomizer. There’s already a Triplanar option, so either an option for UVWRandomizer in the MTL itself or a mapping source input for the UVWrandomizer map would be a very welcome addition.
Hi, the Тriplanar option has some randomization capabilities. What would you like to do with the scanned material that is limited by the options you have?
TriPlanar randomization happens on a per object basis. UVWRandomization happens on a UVTile basis. So I would like to have randomization happen per UVTile, like the UVWRandomizer does, so we can vary in scale, rotation and position per UVTile. If you need to cover a larger surface with a scanned sample of 5x8 cm, for instance the rubber scan, you can very clearly see the tiling. UVW Randomization might counter it at least a bit. All in all the scans are way too small to cover larger surfaces, this might be OK for materials that clearly repeat, but not for materials that don’t.
