Is it possible that vrayscatter doens’t work in Vantage anymore?
I can remember it worked in the past.
Hi thanks for posting. Do you mean it does not work at all? There are some unsupported features but Chaos Scatter works with V-Ray GPU and Vantage. What are you V-Ray, Vantage and 3ds Max versions? Do you have issues only in Vantage or in V-Ray GPU as well?
Here is a screen grab from my simple scene test:
I’ve already found the solution. It is a problem with the latest hotfix from Corona. This one makes Chaos Scatter not working with VRay GPU and Vantage. I believe you are already working on a solution internally.
