I?ve discovered a bug while trying to render Maya particle instanced objects when exported to a VRay Scene and loaded into another Maya scene.
The particle instanced objects render perfectly fine and also work in IPR, but totally ignore the Render Stat overrides and Wrapper settings in the ?VRayScene? node in Maya.
Other objects in the scene respect these settings correctly.
I?ve made a demo scene, which can be downloaded here - Dropbox
Red = Maya Particle instances.
Blue = Standard Maya Geo
Green = Instanced Maya Geo.
You will see the Red balls are always unaffected by the changes, this is breaking a potentially awesome workflow for working with very heavy scenes with lots and lots of instances.
I?ve tested in Maya 2017 using 3.52.02 and Maya 2018 using 3.60.03. Both on OSX.
It would be great to get this fixed. In the meantime if the vrscenes could be modified in some way that would allow the overrides to work please let me know as we might be able to use it on a current project.
David Deacon.
