VRayScene Plugin Overrides Syntax
Hi everyone,
what ist the correct syntax in Houdini on the VRayScene SOP > Plugin Overrides?
I’ve tried the Material Override Examples provided on the official page:
But they don’t seem, to work at all!
My final goal would be to modify an imported vrscene so that all emission is turnded off. This is a common case where I want to add an additional layer of emissive FX and need the vrscene for reflections/refractions.
How should this be approached?
Cheers,
Aleksej
Last time I checked that wasn’t easily done, I’m really interested if that’s changed :slight_smile:
Yes, it was never easy, but this is how it works.
You need to know the exact plugin name or use pattern matching.
It’ll be easier to help if you could just upload some example setup that doesn’t work for you.
You may also try importing the material and re-applying to the particular VRaySceneRef primitive (along with expand primitives option).
However, there are no plans to improve that functionality.
Yeah, we’re moving to USD already.
In your case illumination shader type is BRDFLight, so if you want to turn all of them off the syntax will be:
BRDFLight <*> {
    color=AColor(0,0,0,1);
and the result:
That’s it!
Thank you very much!
