Vrayscene showing up white when using on second computer
Hi
I?m trying to export a vrayscene from 3Ds max to sketchup. Everything is fine when rendering on my own computer, but when trying to render the vrayscene on another computer, the textures are missing.. any thoughts?
The progress log can tell you which assets are missing (accessible through the button at the bottom-right corner of the VFB).
You would need to provide the missing asset files to the second machine.
Upon exporting а vrscene from V-Ray for 3ds max make sure you enable the “Strip Paths” checkbox. Once the vrscene file and all associated assets are transferred to another machine, simply keep them together in the same folder and all internal asset file paths will be autoresolved.
Kind regards,
Peter
Thanks! that was the one button I did’t try:)
