VRaySceneModifierInterface & lights
hi!
I have a VRayPlugin with a VRaySceneModifierInterface that i use to add other plugins in a scene (at preFrameBegin).
Everything works fine for meshes, point clouds, instancers… however, when i try to add a light (LightRectangle for example), i can see the shape of the light (the rectangle), but the light isn’t lighting the scene… am i doing something wrong?
thanks in advance!
You will need to add the lights in preRenderBegin(), before the direct light manager has cached them.
ok thanks i’ll try that!
