I’m trying to render some shadows using VRayShadows Render Elements of some invisible to camera object’s with Vray Next GPU (4.10.03.00001)
I’m having a lot of artifacts on the RE Pass when using GPU, but not problems with the CPU version.
It is happening on both “bucket” and “progressive” mode.
Do you know what is happening or do you have any solution?
I’m having this problem since quite some time now and it appears in every scene I make.
Attached you can see the Beauty pass and the VRayShadows Pass.
I can provide the scene if you need it.
Best,
