vraysimbiontmtl with DarkTreeshader technoxray crashes
hi,
any idea why this crashes vray with … globalillummap::buildlightmap() error?
can i do something against?
using darktreeshader technoXRay.dsts
thanks for help
tomes
using max2016 vray 3-40-02
Dude, this stuff must be ancient. I have co-workers younger than this…
xraymaterial from vray-materials.de… just wanted to test the look of it. but you`re right, its from 2009. but pay attention, child work is forbidden in germany
Nope, he is 17 and our apprentice.
Can you substitute the dark tree shader with a falloff and some noise for bump? Doesn’t look to complex.
thanks oliver,
thought the whole information in the .dsts shader, opened in editor , is more complex than a falloff and a bump ?
don?t know exactly how much of that is interpreted by vray…
thanks anyway
    Shader 1 : DarkTree_Shader Color
        DarkData: 0, 0, 200
        Transform:
            Trans_0 : 1, 0, 0, 0
            Trans_1 : 0, 1, 0, 0
            Trans_2 : 0, 0, 1, 0
        Color:
            Light1_Color : 255, 255, 255
            Light1_Rise : 0.7
            Light1_Rotate : 0.85
            Light2_Color : 128, 128, 128
            Light2_Rise : 0.03
            Light2_Rotate : 0.15
            Surface_Color : Link_To 3 | Color
            Diffuse_Level : 0
            Diffuse_Function : 0.5
            Luminosity : 1
            Specular_Level : 0
            Specular_Function : 0.5
            Glossiness : 0.2
            Metal_Highlight : 0
            Anisotropy : 0
            Anisotropic_Direction : 0
            Reflectivity : 0
            Environment : 180, 180, 240
            Transparency : 0
            Refraction : 1.5
            Clear_Coat_Level : 0
            Clear_Coat_Glossiness : 0.4
            Clear_Coat_Thickness : 0
            Clear_Coat_Smoothing : 0
            Surface_Bump : Link_To 4 | Bump
            Alpha : Link_To 2 | Percent
    External 2 : Incident Percent
        DarkData: 1, 1, 200
        Transform:
        Common:
            Blend_Function : 0.5
            Pitch : 0
            Heading : 0
        Percent:
            Edge : 1
            Facing : Link_To 0 | Alpha
    External 3 : Incident Color
        DarkData: 1, -1, 200
        Transform:
        Common:
            Pitch : 0
            Heading : 0
        Color:
            Edge : Link_To 0 | Edge Color
            Facing : Link_To 0 | Face Color
    Natural 4 : Pumice Bump
        DarkData: 1, 0, 200
        Transform:
        Common:
            Pit_Depth : 0.5
            Lacunarity : 0.5
            Lacunarity_Lock : TRUE
            Roughness : 0.5
            Brightness : 0.5
            Contrast : 0.5
            Pit_Size : 0.25
            Density : 3
            Strata_Function : 0
            Blend_Function : 0
            Input_Seed : 1
        Bump:
            Pit : 0
            Background : 1
            Bump_Scale : 0.02
Trigger_Bank: 1, 1
Tweaker
    Tweak : IF_COLOR
    Tweak : Face Color
    Tweak : 0, 61, 127
    Tweak : IF_COLOR
    Tweak : Edge Color
    Tweak : 129, 237, 255
    Tweak : IF_PERCENT
    Tweak : Alpha
    Tweak : 0.3
Seems to work fine with 3.50.04 - would you please update and see if there is any difference.
If it still crashes would you please pack the scene and send/attach it for investigation?
I managed to crash it, it occurs immediately when loading the .dsts file and gives the following error:
Since those as discussed are way too old I don’t know if this crash is going to be fixed at all.
I’ll make a note into the system but I’m afraid that SimbionMtl will be rather removed from UI than to be improved, unless it is easy fix.
thanks for your work svetlozar, no problem…i have a good material
