VRaySkinMtl dark Edges together with a refractive VRayMtl
Hi, :slight_smile:
I have a problem with dark edges. When I use VRaySkinMtl together with a refractive VRayMtl.
The dark edges appears when the refractive VRayMtl intersect with the VRaySkinMtl.
VRay Version:
vray adv 31001 maya2015 x64
Maya Version:
Autodesk Maya 2015 Sp6
Hope you can help me.
Best regards
Jacob Hansen
Such issues are expected with refractive geometry intersections. Have you tried to enable Affect shadows for the refractive material?
…hmm Affect shadows is on.
Which multiple scattering method you are using ?
Does it disappear if you choose pre-pass based illumination map ?
I use raytraced multiple scattering method.
It disappear if i use pre-pass based illumination map. :slight_smile: But then it do a Prepass before rendering the final image.
Scene file:
http://www.wireguruji.dk/chaosgroup/testDarkEdges/testDarkEdges.zip
VRay Version:
vray adv 31001 maya2016 x64
Maya Version:
Autodesk Maya 2016 SP4
This is fixed for the nightly builds and for the next service pack. You can request the nightly builds if you email us to support@chaosgroup.com and mention this thread.
…Nice :slight_smile:
Thanks and a Happy Christmas
I installed the latest nightly builds:
vray_adv_31001_maya2015_x64_26499
vray_adv_31001_maya2016_x64_26499
And it doesn’t seem to work!?
Scene:
http://wireguruji.dk/chaosgroup/skinBugRefraction.mb.zip
This is not the latest nightly build (it’s a stable build that doesn’t have the fix). The latest nightly build is marked as 3.15.05. You will need to let our support guys know that you need that particular build.
…Thanks :slight_smile: they’ve got a new email where I ask for 3.15.05
…It works :slight_smile:
Thanks for good support and a Happy Christmas.
Glad that it works better now. Happy holidays to you too!
