vrayspawner, DR not reliable to restart after cancel ?
hi,
i m using sp3a with 3dsmax 2009 under vista 64-bit sp1, 4 clients (vista 64bit sp1) with vrayspawner as service ( with account to access network drive)
if i start using DR for the first time, all clients render normal as expected.
but if i cancel the render in the middle of progress, then try to send to DR again, some clients do not start render. anyone know this problem?
thanks in advance
best regards
pt
I can’t reproduce this, but have you tried with the “Restart slaves on render end” option in the DR settings dialog?
Hi vlado,
thx for fast reply.
yes, i checked “on” that “restart slaves on renderend”.
randomly/after hit cancel, some clients will not DR-render, only reboot the clients help :frowning:
pt
hi vlado,
the log say “connected to renderhosts, but the scene is not transferred to renderhosts” do you know why?
it happens, if i dont send distr. render for about 20 minutes. i set no special “power saving settings” in the clients.
thanks in advance
pt
hi vlado,
could you test this procedure in your machine please?
-send DR job to clients (sp3a vista ultimate 64bit , vrayspawner as service with dedicated account to access networkdrive)
-wait about 20 min with 3dsmax open, and then resend a DR job to clients again.
my log say: “connected to render hosts” but scene is not transferred :frowning: , so clients dont load/render
soory still bothering you with this
thanks in adv.
pt
Which 3ds Max version? Have you disabled the viewcube on the render servers?
