Hello Chaosgroup ![]()
after the newest window update and update to the lates NEXT, we started having problems with running Vray Spawner.
Running spawner from a start menu simply doesnt work at all.
We have to go all the way to the Vray folder, and run it from there.
If we run it from that location, we have to run it as administrators otherwise it doesnt work either.
Something must have changed either in Windows or in VRay with the way it handles rights.
All aour computer users have administrative rights, we have UAC completely down, no firewalls, no anitiviruses.
Yet, when we render through PULZE RENDER MANAGER which automatically runs spawners, we and up with the following error:
Executing "“C:\\Program Files\\Autodesk\\3ds Max 2020\\3dsmax.exe” -server C:\\Users\\PIXELB~1\\AppData\\Local\\Temp\\vraydum my2020.max “”
*** ALERT! Could not start MAX/VIZ server: “C:\\Program Files\\Autodesk\\3ds Max 2020\\3dsmax.exe”. Error code: 740. Error string: Requested operation y�aduje zv��en� opr�vn�n�."
Exiting our service due to errors"
Does anyone know whats going on there???
Thanks a lot for any lead!
M
