Only just started using this in an animation job. I want to ‘add in’ a couple of posters on a wall. I hoped to use the vrayspherefade to just render the portion of the image I need from a saved solution (the posters do not generate GI so they should be fine).
I am trying to work out what the bright area is on the vrayspherefade version as this is incorrect. Any ideas?
If I render with Render Region I get this: (this is correct)
If I use the VraySphereFade, I get this: (odd)
Here’s a screengrab of the viewport:
