VrayStereoscopic helper defaut eye distance
When you setup a scene like this:
And create a VrayStereoscopic Helper it defauts to an eye distance of 0.1651m which is 16.5cm
Yeah V-Ray does not like meters, there’s a lot of things that are just weird when working in meters. Camera settings for instance. Or when importing materials set up in centimeters (using procedurals with size parameters): https://forums.chaos.com/forum/v-ray…nt-scene-units the bug has only been in the system since 2 years so here’s hoping…
On the other hand the stereoscopic could have been set up for Anya Taylor-Joy.
Confusing indeed, since when rendering the results will be identical (as they should), so it’s a UI thing. I’ve logged it (internal tracker ID: VMAX-15016) for investigation.
