When you align VraySun to Dreamscape one - forget about vray’ to light the scene. You have to uncheck “render” box on Dr. sun, to render it correctly, as we found it to be geometry thing… Or just move it slightly left or right ![]()
Also - atmospheric channel is slightly brighter, when using VR. phcam.
No offence but I have no idea what your trying to say??
Something about if you align the vray sun to the DS Sun it wont render as the vray sun is kind of blocked by the DS Sun, and you need to move the vray sun to have it render properly?
It wasn’t me ![]()
Yeah, Daforce, smth like that. I should also mention that there’s smth with glossy reflections. Will continue testing ![]()
oi,
just did a quik test..
yeahh!i know this is wacky but vray sun is ignored if u use dreamscape sky…even if u move the vray sun away from the dreamscape´s it ll still be off…
no problem with glossies tho…
I must say that is pretty weird!!!
I will have to try it when i get home later
heh
There’s a lot of weird things… Just testing… >
As smd told ou - just uncheck “render” in dr. sun rollout.
very true! ![]()
