is this this script you wanted to point out:PhysCam Auto-Exposer..is it this one:physcam_lightmeter_1.1c.rar ?
ill give it a try.
Thx;)
ill give it a try.
Thx;)
latter (lightmeter1.1c).
Sorry for untidyness.
In RL it would be overexposed if you had a big enough exposure time, man.
You could have a ZILLION isos, and a ZILLIONTH of a second of exposure time ![]()
re,
Lele
Oooh, than even i could take a steady picture! ![]()
maybe after a few beers eric ![]()
Anyone having issues with white dots in exteriors with VRAYSUN and SKY and physical cam in reflections? Im going crazy with it. If no one is having problems with it, i will post a separate threads showing the problems…
some stray HDRI loaded sample?
Clamping (and subpixel mapping, in case) should fix it, no?
Lele
panthon, would you mind posting up a little image of the issue?
As i dont want to hijack this thread, i will post in a separate one. I´ll see if i can create a simple scene for testing purposes.
Hell yeah dont hijack my post! lol just kidding, but no jokes did nt really get any answer i was looking for, thx for help anyway! If anyones can share the orientation you take with exterior scene for animation with 1.5, that would be appreciated.
I ll post some images when im done with this project.
What I start with, see if this helps.
I load a HDRI into the max environment slot, shove the multiplier up to about 15-20, match the sun position with a vray sphere light and then stick in a physical camera. Turn exposure on, and go nuts with random values till it loks good.
I never use the same global lighting setup because it forces me to redo them every time.
…Turn exposure on, and go nuts with random values till it loks good.
yeah i do the same because the value just make no sense, but it s try and error til it look good…but still it looks good!![]()
For a shot where I’m outside, I normally use iso values around 100, F-stop around 8-11 and shutter speed 60 - 125 depending on how much motion blur I need.
thx for the answer, but i dont think i can use motion blur as it will raise up my render time…and shutter speed is not available with cinematic camera, i dont use the targeted one because its animated in the scene, so i only have sgutter angle left to play with and it does nt do the job, Only 2 option left to balance the image, Iso film and f-stops.
How come youre using the cinematic camera?
As far as i’m aware, all it does is change the values used (helpful if you already know them) and the motion blur/dof.
Although please correct me if i’m wrong.
Im using this camera because its animated and i dont use targeted camera for animation, easier to control since you only have the cam to animate, but after double check i just saw that the still camera can be use without the target and i can have shutter speed to play with so im gonna take a look with the still camera.
