VraySwitch with MultisubObj Mat. on GPU renders Black
is there anyway around this, its an issue with VRaySwitch on GPU , in the same time the multisubObj matrial when applied directly it works fine.
so obviously its a VRaySwitch issue.
thanks.
Thanks for the report. I’ve logged the issue (internal bug-tracker id: VGPU-5607) for developer analysis.
What exactly are you trying to achieve? Send some screencaps to illustrate your desired effect and maybe we can find a workaround.
Thanks, I used to animate the switch material to get many variants of the same product. I was in a very tight schedule so I detached the polygons with another animated switch material.
