VRayToon Render Element - Various Issues
Hi Team
I think this render element is riddled with issues, or I’m misunderstadning how we’re suppose to be using it.
We’re using it in conjunction with the VRayToon Environment Atmospheric Effect
1) I dont see anything in the render, unless I crank up the Multiplier to 100, at which point it seems terribly alliased
2) Saving to PNG with alpha, the resulting file does not look like the render. EXR is fine however
3) In a recent animation, I had 2000 frames, rendered (with the VRayToon’s RE multiplier set to 100). The 1st 500 frames or so, seems to have different alliasing compared to the rest. If I comp this render over my beauty in ADD mode, and bring down the opacity of this layer, there is a VERY NOTICABLE difference between those 1st 500 frames and rest. Almost like the 1st 500 is less exposed by almost half! At 100% opacity the issue is a lot less noticable, but still there if you zoom 200% I double checked, there are no keyframes on my cam for exposure and no keyframes on my sun. The beauty pass looks correct all 2000 frames
Hi could you send us a scene with the issue for review? You can upload it here or through our support contact form
