VRayToon - Set membership
    Does anyone have any advice on how to link VrayToon to a Set ? I’ve tried everything I can think of, but with no luck so far.
In the attribute edtior: “As Inclusive Set” checkbox is available, but “Affected objects set []” is ghosted ?
    I’ve tried manually creating a set and linking it via the maya set editor, but again it’s not working here.
Basically, VrayToon is working perfectly, but I need to animate the opacity of the lines on certain objects.
To create VRayToon effect you must to:
1. Add a VRayToon from the Create->V-Ray->VRayToon menu. Now you can see VRayToon node in Outliner if you uncheck “Display->DAG Objects Only”.
2. Create a Set and add the objects you want to be tooned at it.
3. Connect “UsedBy” plug of the Set to “excludeList” plug of the VRayToon node using Connection Editor (Window->General Editors->Connection Editor).
Outstanding! Thank you Ivan. I didn’t think to use the connection editor (just back of holidays, brain not working 100%). Just what I was looking for.
