Vraytoon silhouette
Hello
It would be great to have the option to trace just object silhouettes and not other edges and just for choosen objects.
For exemple, for the building I choose to render all edges, and for some bush objects just the silhouette outline,…
PLLLEEEAZZ ! :slight_smile:
I second this. I guess it would be nice to set either pixel or world units and say if the line should appear on the outside edge, the inside edge or in the middle of the object edge. :wink:
+1
And separate element for vraytoon and vraytoon outline.
Best regards…
Thanks for the suggestions, I’ve logged them as feature requests.
For now, I think you should be able to remove the interior lines if you set the normal and overlap thresholds very high.
