Hi
Is there any way to get VRayToon to work with the dome camera?
Hi
Hi what do you mean by “dome camera”? Are you using VRayPhysicalCmaera in spherical mode? The VRay Toon works with all camera types. Could you explain a bit further what are you using?
Hi. Thanks.
I mean the VRayDomeCamera.
Well this is strange.
I was using the VRayDomeCamera set to 180 degrees. It seems that VRayToon will only work up to 179.7 degrees.
Can you confirm this please?
Weird. I’ll upload a file.
I’m on max 2020 and V-Ray Next 3.3.
The attached file renders no toon at 180 degrees and toon at 179 degrees.
domeCamToonTest_001.zip (27 KB)
I tested with 3ds max 2020 and V-Ray Next 3.2 (latest on our downloads page) in you scene and it does not work. However in a new scene the VRayToon works fine with VRayDomeCamera?
Are you using a nightly version of V-Ray Next?
Thanks.
I just tried it in a new scene but it did not work either.
My version of V-Ray is V-Ray Next update 3.3 (4.30.03 build 30952) installed from the file ‘vray_adv_43003_max2020_x64.exe’,
Hi this is a stable version from the 25th of August. With it indeed the toon is not working. I suggest that you install a different version and go from there.
I see vray_adv_43003_max2020_x64_31225_install.zip as the latest stable. I’ll give that a try.
Thanks for the help.
I tried 4.30.03 build 31225 but no luck. Same results. Any chance of a fix? I’m using recent builds because of a Phoenix bug with VRayVolumeGrid.
Thanks.
