VRayTranslator ignores post translate code
I got a VRayRender node that uses this post translate script to output to angular map/dome master:
from vray.utils import *
domeCam=create("CameraDome", "__camera_dome__")
domeCam.set("fov", math.pi)
However, when exporting a vrscene file and rendering via standalone this code is ignored.
Is there a workaround?
Cheers,
frank
Hey,
The post-translate script happens after the export of the scene so that’s why it’s not working.
Instead of that post-translate script you can use VRayCamera instead of the regular camera and set it to behave like a dome camera.
You can find more at - V-Ray for Nuke
I had checked out the projection types in the VRay camwera but could not find a dome type. Only fisheye and that’s different.
You can set the type to Spherical Panorama and override the FOV to 180 - this should give you pretty much the same result as the post-translate script.
but that produces an equirectangular image. I need an azimuthal equidistant image like this:
Ah, my bad. Totally missed that.
A simple workaround for the Standalone issue would be to open your vrscene file in a text editor and add the following lines:
CameraDome camera_dome {
  flip_x=0;
  flip_y=0;
  fov=3.141593;
This is essentially what the post-translate script does.
It doesn’t work because there is already another camera in the scene (the regular perspective one). However, in Maya, you can add the V-Ray dome camera attributes to the camera you normally render from:
https://docs.chaosgroup.com/display/…era+Attributes
Thanks Geori, I will try that. Vlado, can this be implemented as another projection type in the camera itself in a way that the standalone will pick it up?
Yes, see my suggestion above. If you add those attributes, V-Ray will export a CameraDome plugin into the .vrscene file.
oh, I misunderstood. It sounded like this will work in Maya but not Nuke. I will have a look, thanks.
yeah, I’m a little confused now. How would I add those attributes in Nuke? Is this something I can do in the VrayTranslator’s parameter override?
Also, in the link you posted a equirectangular image is shown, not a dome camera i.e. equiazimuthal).
Ugh many apologies, I just now realized this is in the Nuke section; not sure why I thought it was Maya. You are right, we need to add the dome camera to the options - I will make a note about it. So many editing the .vrscene file is the only thing to do for now.
Ah great, thanks for confirming. Happy to edit the file for now.
