Hello all!
I have 2 main problems with a FBX file coming from Revit
1. I cannot tweak the texture with “UVW Map” modifier if I use a material with VRayTriplanarTex. To modify the texture I have to work with Map settings or VRayTriplanarTex settings (I have been checking all Map Channels and they are all correct).
2. The second problem is a bit more complex: Within a material I’m using a VrayDirt to simulate a variation on the corners of a balustrade. I’ve imported the FBX which is coming from Revit and I work in MAX “System Unit Setup” in “Meters” and the VrayDirt effect doesn’t work, but I try to switch “System Unit Setup” to “Inches” the VrayDirt appears normally.
If I try to remodel something in the Max file with “System Unit Setup” in “Meters” from a scratch, VrayDirt is OK but if I model something starting from something from the FBX imported (i.e. a copied edge) the issue is coming back again.
I was thinking: A.The FBX file form Revit is corrupted and it keeps the unit from the original Revit file.
B. The FBX file is importend in a wrong way (I use a default preset “Autodesk Architectural (Revit)”)
Do you have any idea about that???
Thanks a lot
