VRayUnclampedColor
In V-Ray 5 update 2, the DeepOutput and Multiplier parameters have been removed from the VRayUnclampedColor element.
Does this mean that the VRayUnclampedColor element is effectively no longer needed due to the removal of the “Clamp Output” parameter from the ColorMapping?
We’re aware of the missing parameters issue (internal bug ID nr.: VMAX-11701). This is fixed internally, and we will let you know once the fix is available. Thanks!
Thank you for the details.:slight_smile:
Would you please reflect the internally fix in Nightlies?
It could not be confirmed in Nightlies of 20220112.
Our customers who have pointed out this issue have tight deadlines and are dissatisfied with the inability to use traditional VRayUnclampedColor Element with Multiplier workflows.
We’ll try to get it in the nightlies tomorrow.
thank you.
I will wait for the reflection in Nightlies.
