vrayvelocity in nuke?
anyone got the vrayvelocity to work as velicity blur in nuke ?
Thanks !
Found this in vfxtalk.com
Use the “multiply” node. It is not in the menu, just go to others and >“update all plugins”, then go to the letter M and select “Multiply”, now select you VRayVelocity pass and deselect x and z and type -1.
Voila now you have applied a -1 to the Y. and Made the vectors go to the correct side.
Hope it helps
