VRayVolumegrid renders still but not animated sequence of VDB files
I’m trying to use VRayVolumeGrid to load a VDB sequence (source is Embergen) using VRay
Weirdly it will render any single frame, and the VDB shows in the helper, but when I set an animation going it just renders blank frames?
Vray 5 update 2.3, Max 2022
Has anyone else come across a problem like that?
Thanks,
Steve​
Usually, EmberGen sims are non-physically accurate and need adjustments. I was recently involved in matching EmberGen results to V-Ray such. Here’s the thread, and try the suggestions from post #6.​
EDIT: Pardon, I just read that it renders Single Frames fine. Either way, check if our suggested setup helps; otherwise, send the scene and a few .vdbs files so we can troubleshoot.
thanks - have sent an example - digging deeper it seems to work in volumetric mode, but not as meshes (renders meshes as stills but not as a sequence?)
Okay, here’s what’s happening: only the first few frames are not visible (which I presume led to the confusion of animation not working), because they are below the isosurface level (except frame 0, which is an empty .vdb of 2 kilobytes). A value of 0.04 seems to work fine. Try it out.
Thanks, yeah got it working - it was showing in the viewport with those original settings which is what confused me
Thanks again!
