how do i save my files from the vray frame buffer in the vrimg format ?
Chris
Chris
It will not work right now; the .vrimg format can only be saved during the actual rendering process. I’ve made a note to implement this.
Great, Thanks.
Another thing you may be able to help with, although not a vray issue but a photoshop issue. When I open my EXR’s in photoshop the alpha channel is always pre multiplied do you or anyone know how to turn this off?
Chris
good question, I’d like to know a solution to that as well.
This was discussed over at the V-Ray for 3ds Max forum at one point; I think the solution was to use some PhotoShop plugin for loading the OpenEXR files.
Yes, ProEXR. Well worth the $95.
great,thanks.
