hi,
Rendering an image over 4000px wide doesn’t work, it gives an error in backburner or simply hangs if I don’t use backburner. So I tried vrimg, which worked well in the past. But now it doesn’t work either, even on a new scene with a simple teapot.
I’m using rc4 x64 and max9 x64. Also tried rc3, same issue.
Tried strip rendering but that crashes too, but I read this can be due to the vray frame buffer, didn’t try it any further. For now I did a crop render and manually moved the crop region for each ‘strip’ ![]()
Anyone else having problems with vrimg format?
