that is not supposed to happen, all channels should be there. which application were you opening the exr with?
as an aside, if you’re not comfortable with the vray image format you can always save the channels as individual files. there’s a split render channels checkbox in the frame buffer rollout.
I am using photoshop cs4e
to open the .exr
but I know the vrimg has the channels I want
Since I am working in linear space, I wanted the 32 bit output and the render elements. I was previously doing the render in 2 passes to get these channels.
I know lele has a script that runs in max but I don’t know of any standalone converters
raj
the problem are not the exrs from max, but photoshop.
ps can’t handle multichannel exrs, it reads only rgb and alpha. the channels are there, but you either need a plugin such as pro exr to extract them in ps, or an application which does that natively.
Thanks for reminding me about fnord thingy
I had it but it wasn’t installed properly
Alll is well
step1: drag and drop files onto vrtoexr.exe proram
step2: drag and drop onto cs4
step0: install proexr and rename orignal exr plugin to something else
Raj
