vrimg2exr - converter
i ran a search, but could find anything in the sketchup section, so im sorry if this is a repeated issue, and i appolgize if this is a newbie question but how the hell do u work the vrimg2exr - converter???!!! when i click on the .exe it open a black window then disspears again???
any help would be appreciated
Regards
Re: vrimg2exr - converter
Downloads> Tools and Scripts> All the way at the bottom
hi yes i meant how do i use it, but i think i figured it out
Sorry about that…
Here’s the spot 3d page. Note: not all channels mentioned on that page will be available.
Also, if you have a vrimg and you right click on it, you should be able to tell it to open with the converter, which should do a base (RGBA) conversion. I’m not 100% on that though bc I set it up years ago. All I know is that now I double click on a vrimg and it does it automatically.
