VRLServer as service doesn't recognise VrayRT
I can only get the server working when I run the license server from the Start menu… running it as a service seems to run the ‘old’ license server (ie when accessing the server from a browser, you see the old interface with no reference to VrayRT)
Would be easiest if you re-register the service with the latest one.
How do I do that?
Start menu - chaos - vray for max2010 - licensing - register vrlserver as service
? or is there somewhere else I need to go to find the updated server as service?
Yep, I think this should be enough.
or is there somewhere else I need to go to find the updated server as service?Nope, it’s in the same place as the standard V-Ray one.
