So since the textures used by vrmats doesnt show up in asset tracker, I can use a text editor to modify the paths inside the vrmat.
BUT
Seems the vrmat likes to see linux paths // instead of windows paths \\ (or at least the ones I’m dealing with)
I need to map to a mapped drive, so then if I edit the vrmat to show to P:\ for example, will DR pick up the textures and will the vrmat still work?
I will make a note about it, but I’m not sure when it can be implemented. If we implemented support for relative texture paths in .vrmat files, would that work better?
I also now noticed something weird, some of the vrmats textures “automatically” picked up the “correct” path, while others show the old UNC path. Very weird.
These VRmats and the export import from other app, truncating of file names etc, Seriously… It would just be so much better in max if we can just please convert the vrmat to a normal VRayMtl
It’s not always possible to convert .vrmat files to Max materials - there are some texture nodes that are not present in Max. There might be other ways for us to do that in the future though.
It’s almost completely useless to have vrmats in Max as you can’t mass edit them in any way. I’m now manaully editing each vrmat (xml) to change paths. Not fun when there’s 246 of them.
Also, you have to BROWSE for each vrmat, you can’t just drag and drop it into a VRayVRmatMtl, which makes it even longer to work with these. So far I also haven’t found a way to display the diffuse in the viewport, so difficult to tell which objects have the correct material or not.
Extremely frustrating
I still think something that can convert the vrmats from Rhino to Max VRayMtls would be best. Even if it is just best effort close as possible with the 1:1 features, and ignore the rest.
It’s xml files, can’t be that hard to write a script to convert to VRayMtl.
