Vrmat with multiple materials not rendering properly
Seems like the vrmat material doesn’t respect the face ID of the object, just assigns the same material to all face IDs.
Same thing happens on a plain box, so it’s not a proxy issue, seems like a material issue.
I have the right material name selected not sure if this is a bug or there is something else I need to do.
I am also getting a strange error, but i’m not sure what it is, seems like a missing parameter.
All the assets are from the Cosmos library.
The VRayVRMatMtl does not contain material id information. Try applying a Multi/Sub-object in which a node for each material in the VRayVRmatMtl is connected.
Maybe I don’t know what I’m talking about but to me it seems like it does, there is a list of material IDs in the main material.
Also the preview sphere renders like the multi material, its showing the sub materials when selecting the main “_3DM…” material from the list.
To me this seems more like a bug and not a lack of feature
<Asset renderer=“vray” url=“/_3DM_Saki_Posed_009_mtl@mtl_12” type=“material” layout=“”>
<plugin>
<vrayplugin name=“MtlMulti” type=“material” version=“0”>
<parameters>
<parameter handler=“default” label=“scene_name” name=“scene_name” listType=“string” type=“list”>
<value>
<list>
<entry>_3DM_Saki_Posed_009_mtl</entry>
</list>
</value>
</parameter>
<parameter handler=“default” label=“wrap_id” name=“wrap_id” listType=“none” type=“bool”>
<value>1</value>
</parameter>
<parameter handler=“default” label=“ids_list” name=“ids_list” listType=“integer” type=“list”>
<value>
<list>
<entry>0</entry>
<entry>1</entry>
<entry>2</entry>
<entry>3</entry>
<entry>4</entry>
</list>
</value>
</parameter>
<parameter handler=“default” label=“mtls_list” name=“mtls_list” listType=“plugin” type=“list”>
<value>
<list>
<entry>/Saki_Posed_009_mtl@mtl_13</entry>
<entry>/Stroller_Fabric_mtl@mtl_14</entry>
<entry>/Stroller_Plastic_mtl@mtl_15</entry>
<entry>/Stroller_Chrome_mtl@mtl_16</entry>
<entry>/Stroller_Rubber_mtl@mtl_17</entry>
</list>
</value>
</parameter>
</parameters>
</vrayplugin>
</plugin>
</Asset>
Those IDs are a different matter. Check this thread for more information.
Thanks, i’ll follow up on that thread.
