vrmeshes from blender are too small
Not sure who to report this to. Vrmesh proxies from blender import too small. They are tiny. Probably 1% of the size they should be when importing into unreal.
Hi, Nerva
Can you please send a sample vrscene with this issue at support@chaosgroup.com so we can investigate further.
Alexander
Thanks. Email sent to support with attached vrmesh.
Hi, Nerva
I’ve checked the vrscene and it looks like that it is importing correctly as defined in the vrscene. Can you please send the blender file. Maybe there is a setting in there that can explain what is happening. You can send it to the support team in the same ticket as well.
Alexander
You can just create a default 2M cube in blender with units set to meter. I sounds like the blender Vray plugin exports at the wrong scale! If that is the case, depending on how physically accurate of renderer Vray is that is potentially a bad thing.
Howdy, Nerva,
As an attached file I’ve added blender file and exported vrscene from Blender nightly build(cube is downsized to 0.2m) in order to avoid the confusion. Cloud please check it.
Cheers,
TEST Blender.zip (101 KB)
Thanks, boyan, but I am confused. Were you unable to reproduce? Or were able to reproduce, and have posted a fixed blender build? Or your scene demonstrates a particular setting required? I’m sorry, I’m just not sure exactly what is the status of the bug, and additionally what is being asked of me. Sorry.
Hi, Nerva
Did you by any chance export vrscenes from blender as separate files? Because the vrscene that you send had only geometry data and nothing regarding materials or global settings. This may be the issue here. There is a specific parameter in the vrscene called meters_scale which is essential in the correct construction of the geometry when you import it in Unreal. Can you please generate a vrscene without splitting it into multiple files and then try to import the single vrscene.
If you try to import only the _geometry.vrscene you will lose the scale of the mesh and will be imported incorrectly, that includes the vrmeshes. Please tells us how it goes.
Alexander
OK. Thanks for that explanation. I believe this may be the case. I will test again when I get a chance. I think this knowledge should be added to the vray for unreal documentation.
