When using maxscript to export a vrscene. I noticed that no matter what arguments I supply the function, it will not export any animation. In my case i made a simple teapot spinning and it will not export the animation with the following code.
No matter what settings i use it always generates an 8kb file. It should be closer to 118kb since the teapot is animated spinning. How can i fix this?
thank you
Here is my max file and script
