Vrscene export: Missing Forest Pack objects
Forest pack objects seems to randomly be omitted from the export. What can be the reason for this? Using Vray 7 and the latest FP updates. I have to do numerous exports to eventually by chance make them all export successsfully… Very time-consuming!
There are no issues with a simple setup. Would you mind attaching (or sending) a scene and where this is happening?
Hi. Thanx for reply.
Done some testing. I’ think it might be a lack of RAM problem? The file is huge so I saved a new file to test on and deleted alot of objects leaving only terrain (surface host) and Forest Pack scatters to export. Then all scatters export and open fine in Vantage. But I don’t know excactly where the limit is or if a certain object causes it. I will test on another machine with more RAM and report how it behaves. Where to send the file if you want to take a look? I’ll probably have to use wetransfer or something.
Thought I found the reason. Using tyflow for terrain and exporting this to terrain mesh, so when editing terrain for the roads I forgot to reattach to the newly exported mesh terrain for some scatters. Did not see it because the scatters show up in the 3dsmax viewport as they are also attached to the hidden tyflow terrain object.
But still one scatter won’t export. Where can I send file if you want to have a look? Wetransfer?
:slight_smile:
Here.
I sorted out the problems now. :-)The missing Forest Pack objects was due to the FP camera setting “limit to visibility”. I forgot setting it. As simple as that. Thanx for your time!
