Hi
Is there a way to override the materials on vrscene objects when wanting to make a white render using the material override option?
Hi
The VRayScene object is self-contained and its materials cannot be modified or overridden. You if you have the source scene you can use a .vrmesh file as a temporary workaround.
A fix will be included in the next update.
Kind regards,
Peter
Hi Peter,
I know this is an older post but have there been any updates to this? I basically need to override the materials in a certain render pass (Maya) with a single material.
Thanks!
Jonathan
There is a task logged about this which is currently pending development. I’m afraid I cannot yet confirm whether it will be implemented in the upcoming Update 2 or later on.
Kind regards,
Peter
Hi guys,
V-Ray Next for SketchUp, update 2 is released.
The global material override now affects Proxy Scene assets (vrscenes).
There is also a way to disable that behavior for backwards compatibility reasons.
Regrads,
Konstantin
