Hi. Is there a way i can convert vrscene from from (3dsmax) and convert it to proxy mesh?
Hi x_architects,
There is no direct way in which a vrscene can be converted to a Proxy Mesh.
There are however a couple of things you can try:
Vrscenes can be imported for editing in SketchUp using the File / Import workflow.
Just make sure to change the file filter to .vrscene.
Note that only diffuse colors of materials will make it through.
If that works for you you can later convert the imported objects to a vrmesh using the Proxy mesh export in V-Ray for SketchUp.
Another option is to create the Proxy Mesh in 3ds Max directly.
The same proxy can then be referenced in SketchUp.
In this workflow the materials will have to be potentially re-created and reassigned after the proxy is referenced.
Can you give me more details on what your end goal is?
Why do you need this conversion?
Konstantin
