Vrscenes for Hydra Render Delegate?
Hi, I was curious if there was any plans to add support for vrscene lop in the hydra delegate? I would really like to use Houdini to help control and automate a portion of my work’s projects but as we use vantage for arch-viz we need to be able to easily work with scenes coming from Max which means USD shader conversion is pretty much out of the question. I figured even just the ability to render a vrscene lop could be enough to justify lighting and render automation inside houdini as we often have upwards of 8+ seperate vrscenes per project and are often looping back to update things. I’m not entirely positive how this works on the developement side of things so forgive me if I have any misunderstandings!
