Vue 9 and VRay 2.0 - Nothing Renders
I am not sure what to do. I’ve used Vue in the past, mainly Infinite and not XStream, but now in 3Ds Max when I build something and click render it just doesn’t show up!
I have VRay set as the render engine, and anything I made in 3ds Max is fine and there, but any vue objects are not. I did the latest patch and am not sure what I am missing. I am using VRay 2.0. Any help would be appreciated!
atmosphere effects add Vue effect and it should work…
Apparently you need to let the render get to end and then the 2nd time you render it will work…depending on if you have setup the vray scene first or not and if the effect has been added. Otherwise try the above.
Im having the same problem and have yet to test out what ive just stated. Would be interested to see how things go. Im pretty sure this worked straight away with Vue 8..
Make sure you have at least 9005575 and the special Vray 2.0 plugin installer for Vue…
