We have run a few quick tests with Vue xSteam Personal Learning edition and it seams to be working correctly with Vray.
We recommend you to forward this request to e-on software for their official answer.
Thanks. Can you please paste some images of the preset scene that come with Vue rendered using VRay. Will be delighted if you can show some renders done using Vue trees, procedural rock terrains, god rays and clouds.
Yes , I wanted to do that but unfortunately there are no preset-scenes with personal-learning-version.
I’ll send a request to e-on - and I’ll update you if they agree to send us a few example scenes.
We’ll have to test again and see. A lot of things have changed since 2013 and I would expect this to work with IPR. Unless you’re interested in something other than IPR ?
I just would like it to function normally .. it only seems to render when on cpu so far on my machine. even with 3.06. NEXT - it just crashes Maya.,Also… since there is no “REAL” way to contact Bently et all .. about this other then a support form. which I’ve done.. its hard to know if this is even on their radar.
yes cool please let me know.. I think at this point that with next the 2 plugins loaded crash Maya.. so… not a good start… though might just be on my machine.. Mac osx which may or may not matter.. I think I got it to load once but.. I don’t think any added item from the Vue side showed up unless I converted it to native assets.. which I thought was something you didn’t have to do with v-ray and Vue.. from what e-on says..
right now I can’t even get vray next to load in Maya 2018.4 out of the box.. “shipping build of next” I even killed my plugin prefs and just tried to load the vray bundle and boom. I will post this over in the correct forum.. as well. dumpdata.zip (51.3 KB)
This would be osx 10.12.6 and later.. with anything past 3.x vray. Looks like its vray next changes that effect this.. and i suspect that vue folks are behind on their updates …
Can you try uninstalling V-Ray, making sure that all files are deleted (i.e. there is no vray folder in /Applications/Autodesk/maya<version> ) and then installing vray again?
Sadly I cannot.. No longer have access to the Maya install… But if I install 3.x it’s fine and world with Vue but 4.x did not. Happens on two machines different os’s even…10.12.6 and 10.13.6
