Seeing as its vehicle season, here is one I did earlier, teaching myself to model cars.
Tried a little bump in paint, did try a bit of rust but was too consistent, texture looked OK but ‘splotches’ of rust not random enough and still cannot master UV unwrap, either works great (not often enough) or every face is rendered in mesh guide ouput?
Looks pretty good.. a little clean perhaps.. especially for an old kombie
Also usally the inside of the wheel arches are not the same color as the car, as the body usually doesnt continue around that way, often there is a rubber/plastic shield around there. Thats the part that stands out to me the most.
p.s. no need to make a 2nd post a few minutes later, you should have just edited your 1st post
