VW type2r .WIP!
WIP!
Concept bus, based on old type2. It’s a project for my university. C&C are welcome :stuck_out_tongue:
Re: VW type2r .WIP!
Funny car. Good Vray start.
Only the deep shadows … Do you use Rhino 4 and one of the latest Beta? If yes, than enable output gamma 2.2 and correct textures/colors at the global switch options.
Re: VW type2r .WIP!
:slight_smile: Rhino 3 sr5. I need some help for the front lights too(trying to make a xenon light)
http://www.tuning.sk/images/news/as\_design\_lights\_news\_160506/as\_design\_vw\_golf\_4\_front\_light.jpg
Re: VW type2r .WIP!
Rhino 3: you must use a Linear workflow setup (LWF): output gamma 2.2 and all textures corrected with gamma .45 at the texture dialog. Colors are not so easy to correct, you can go by trial and error or create a color texture and use the gamma correction of the texture dialog again.
It’s a must, any other is wrong. :wink:
VfRhino4 support an easy to use gamma correct workflow.
Re: VW type2r .WIP!
very cool model and love the render. :stuck_out_tongue:
Re: VW type2r .WIP!
10x,Travis Serio.There is a lot of work to do ::slight_smile: for reaching best results :stuck_out_tongue:
Micha,i’m instaling Rhino4 now & V-ray demo 4 :P.
Re: VW type2r .WIP!
Using an emitting materials might help with doing the headlights. Simply add an emissive layer in the materials rollout and adjust the color/intensity. Also the bezel around the headlight is going to affect things as well. I would think a nice highly reflective material will do well.
