Hi … I keep having these log errors… when i start live link with vantage 2.0…
do you know how to solve it, or what can cause the problem?
thank you
Do you have Vantage running when you do this ? Or maybe a firewall is blocking the connection ?
Greetings,
Vladimir Nedev
Are you sure you have a license?
Yes I do and works
Yes I do and is running, all the software connected with the license work perfectly… vray an d phoenix fd… no problems
yes I did also tried the firewall
Does it get fixed if you restart both 3dsMax and Vantage ?
Greetings,
Vladimir Nedev
I have tried but unfortunately not… I have tried also to reinstall Vantage but nothing seems to work it works only if i export the scene as vrayscene
Yes, but Vantage was removed from Premium. I say becasue I had the same error and it was becasue Vantage 2 came out, and was removed from Premium, requiring its own seperate license.
Before attempting Live Link, start Vanatge from the start menu or desktop. Check if the Live Link menu looks like this screenshot: Chaos Vantage
If it does and you still get the same error, I think it’s 99.9% caused by security software blocking the connection.
DID they remove it from premium while i had already paid for…? that is unbelivable.. really? that is not correct… to change when i paid in advance for the whole year subscription… thanks for the info… then you might be right that is why is not working…wasting alot of time looking for a solution… not even an email where they advise the change
Yes, they removed it from the premium package and it is now its own things. The premium package also stayed the same price. They sent out some emails about the change.
No, Vantage was NOT removed for users who HAD bought premium before 2.0 was released. It is available for the remaining duration of these subscriptions. It is not included in Premium only for purchases made after the 2.0 release.
Yeah, I don’t know. It should work, unless your subscription was renewed somewhere in there, then it wouldn’t work. My subscription was auto renewed right when V2 came out, so I lost it. They said that V2 would work as long as your subscription was current. If you had 6 months left, then you would have V2 for 6 months. If you had 6 days, then you would have vantage for 6 days.
It’s pretty easy to check if Vantage renders anything, even an empty new scene. If it does, the license is certainly not the reason for this “Could not connect to host” error.
