Warning: Installed driver version is newer than latest verified one
Hello! I just installed the V-Ray for 3ds Max 2023 Update 1. Before updating I did not receive any warnings. But, afterwards, when I use the V-Ray GPU 6 Update 1 to render, I receive the following warning:
Warning : Checking CUDA driver version: 5001: Installed driver version (528.49) is newer than the latest verified one (526.9)!
I searched and found the post quoted below. The advice to revert to previous versions of the CUDA driver seems clear. That being said, I still wanted to create this post to double check.
Thanks in advance!
Hi, thanks for posting. The recommended driver on our V-Ray GPU page is tried and tested and is proven to work best with V-Ray. You should have no issues with the newest driver from Nvidia as well in most cases.
Thanks very much. I assume it is best to just find the driver of version 526.9 on the Nvidia site. I know this is pretty obvious, but I figured I would ask. I am using a new workstation so I am unable to simply rollback to previous driver versions.
Much appreciated.
