Warning : Max sample level set to 0 - rendering could take longer than expected. Consider setting a value to decrease the render time (i.e. 10000).
When I start a new render using CUDA and interactive render I get this error in the log - but I don’t see the “Max sample level” anywhere in the settings?
Can anyone help / explain what is wrong?
Jorgensen
Hey @Jorgensen_cg
You can safely ignore this warning, we have a task to remove it from the log soon. It means that interactive rendering runs without a target threshold or samples level. This is totally fine and should be the expected behavior.
Best,
Muhammed
Ah ok - thanks
