warning message
I get this message after I set up batch render in 3ds max 2024. how to fix it?
Thank you.
You probably haven’t set up an output location, and it uses the default. Check your permissions for that folder. Also, is your Win username “User”? If not, maybe this is why it doesn’t find the folder.
