I think that is a displacement issue. Try turning of displacement globally to narrow it down. If that is it, raise the edge threshold. I know Poliigone materials come in at a threshold of 2, which causes us issues, so we set it to 4.
Thank you for your suggestion, i will give it a try.
Do you mean this? if yes, it already set to 4 (default)
Did you try to disable displacement to see if that was the issue?
You can disable displacement and other stuff globally in “global switches” tab
also 3ds max has this swtiches in common tab
“Null” word means to me that theres no info in your vray proxy file, does it work in other scenes? maybe it is a link issue, whats the texture status in asset trackin? have you tried reloading them?
Or maybe changing to dynamic mesh instead of static mesh in the proxy settings, its been a while since I did that so dont know if theres still that option
It would be best to send the scene showing that message to our support. In general it shouldn’t happen.
Yavor
yeah, it is proxy issue. I convert a Corona file to V-Ray, the V-Ray converter always missed corona proxy.
Thanks for all the input.
