I know it’s stupid, but sooooo often I have left under stress the “test resolution button” on..
and everybody has it on his daily checklist, because it quickly messes up all renders (if they run maybe in worst case over weekend)
PLEASE ADD A WARNING or MESSAGE WHEN TESTRESOLUTION IS ON
and a sequence is rendered. Or implement a button.
The VFB interface buttons are anyway very very small on a highresolution display and hard to read.
It would be anyway great, if anything that does not work or is not supposed to work, gets either a warning or another hint ![]()
EXAMPLE 2:
it’s always “filtering” with progressive rendering, despite you are disabling this. where should a user new know this? and when you come to the point in compositing, that you can see some channels with contrast, it’s too late.
EXAMPLE 3:
A file is not compatible (indexed color) or missing. The only warning is, that it can’t “create a thumbnail”.
A thumbnail is nothing important, but a missing file is crucial. So the Warning should tell that.
Thanks!
