I’m trying to render a watchstrap made from nylon webbing similar to the image attached.
My method has been to make a single surface on which I displace a cloth texture (the one included in vray for rhino procedural textures). I then duplicate the surface and flip the normal to create the opposite side. See sample attached (blue strap).
It sort of works but I know there must be a better way. How would you go about doing this? Anyone have a hot tip?
I checked my old files and found that it was a quite simple box mapping of the attached fabric structure only. I created a flat version first and mapped it, later I bend it to the needed shape per _flow. I have done the watch rendering some years before and so far I remember me I could used different ways.
Apply a mapping on the flat strap and bend it per _flow. If you get problem that the mapping get wrong by _flow, than you need to convert the NURBS to mesh first, apply the mapping and save it as OBJ and reimport it. So, the UV are burned in the mesh and can’t get lost. But you need a fine mesh for the flow or you get no nice bending.
For leather straps I use a planar projection. Or in this case you can bend the NURBS together with a planar surface which can be later used as custom mapping object - see last screenshot.
